Method Race Wheels-Can you run a Hub ring and the center cap?
jrob56
So I picked up some used Method NV wheels with hub rings, center caps and Gorilla Lugs. I know these aren't hub centric wheels. If I put the hub ring in it prevents you from using the center cap unless I'm missing something?
Any help?
Thanks,
Josh
Your correct. One or the other. Lug centric is perfectly fine, just pay attention to your bolt sequence and tighten off the ground
Thanks just checking sanity, gonna use the cap and leave rings off. If I have any trouble with shakes or vibes I'll swap and try the rings.
