Footwell constant hot source ?
I posted on here the other day and I got the help I needed but I'm now looking for a constant 12v power source for the leds. Not the dome light wire just any 12v constant source , Is there a circuit i can tap into in the driver side fuse box ?
Appreciate any feedback!
Sent from my SAMSUNG-SM-G935A using Tapatalk
Yes, in the same picture, I also have my lightbar hooked up. Red wire lol.
Well engine area. I'll have to take a picture i wanted to post tomorrow.05362f6d4a91386567ad8b06c7f4d59f.jpg
Sent from my SM-G935T using Tapatalk
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
