2015 2500 backup lights and mirror lights?
hey fellas, i just upgraded from an 09 1500 5.3 to a 15 2500 duramax, still cant wipe the shit eating grin off my face the torque provides me, wife seems to like it to and drives the thing everytime she can, lol. ive got the towing mirrors with the led lights in them. im trying to get them to stay on when i put her into reverse. one thread said to turn them on while in park and then go into reverse but that seems to shut mine off. im guessing its an early 15 truck and not the 15.5 that ive read about. im trying to find the thread for it, one i came across was 19 pages long and after about page 9 i gave up on it. so the quick and easy, does someone know off hand what two wires i jump together to be able to turn these guys on with the truck in reverse? another thread was mentioning a diode, one said a wire jumper. then it got off topic about other stuff. basically just want to be able to turn them on and off with the factory cargo light button so i can back up my trailer into my dark driveway a little easier. thanks very much
well i jammed a wire into the two slots from the post i linked above and she works. still debating if those leds are going to be too bright to have on as approach lights at night time or not. so i guess i answered my own question and with motivation and boredom did the mod myself, lol. does it matter what size diode i use for this mod?
A diode only pushes power one way. So when installed like this photo, the cargo lights would come on anytime the reverse light is on but not the other way around. If you used a wire, they would come either way. When in reverse, Cargo comes on. When cargo comes on, reverse comes on.
Check your upper glovebox for code AVF. If its there, then you have to hit the cargo lamp button and it will say "cargo lamps enabled". They should come on in reverse and shut off in drive on their own.
If you do not have code AVF, then you have to do the diode mod above and then you don't have to hit the cargo lamp switch, the diode mod lets them automatically come on in reverse.
I had to do the diode mod on mine (early 2015 HD) and it worked excellent.
thanks fellas, im guessing mines an early because it kept shutting off on me when id go into reverse. do you guys know by chance if it matters what diode i use? id imagine all its doing is sending a signal to a relay to turn it on so really, the bigger the better in this case right? but really it shouldnt matter id imagine
One of the threads had the part number from Radio Shack 1N004 http://www.gm-trucks.com/forums/topic/164156-cargo-lights-on-with-reverse-lights/?p=1495649
Ok, so my cargo lights come on but to me it makes the mirror lights useless because of the glare from the cargo lights when I look through the back window in reverse. How can I disable the cargo lights but get my mirror lights to stay on in reverse?
thanks, ill grab a pack of those. i finally had a chance to play with it at night time over the weekend. amazing. love the amount of light these give off while approaching and reversing the truck into a pitch black area. the only thing im not a fan of is the blinkers in the mirrors and how they seem to be aimed at my eyes on my side. my 09's towing mirrors were either pointed a bit further out or not as bright as these. aside from that, no complaints.
'15.5 was first truck to get the LED lights in the mirror. Sorry that is all the help I have to offer...
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 890 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
