Tick, Tick Tick
GMC-AT
2016 Sierra 4x4 Double Cab.
Need some help. I get a tick, tick, tick sound at low speeds coming from the passenger tire/hub area. The tick sound is consistent with the revolutions of the tire turning.
I speed up, the tick speeds up. I slow down, the tick sound slows down. When I get to about 30mph, the sounds stops.
Also- sometimes the tick sound will stop for a few seconds then start again.
It's like there is a nail in my tire.. that's the kind of sound. However, I know that's not the issue because it was happening of a soft dirt road.
Any ideas?
Pull tire and check brakes,suspension. Look for anything not supposed to be there. Probably already did that huh....then maybe retorque lug nutz
Something in a tire? Screw, rock, nail?
My stainless clad, steel wheels, have a squeak from the wheel weights rubbing the tire bead as the tire flexes...
Had it on my wife's Buick.
Rusty spot on the rotor and a brake pad with a little movement in the caliper.
Was like:
tick, tick......tick, tick, tick.......................tick..........tick,tick..tick,tick :)
so long
j-ten-ner
