6.2 fuel milage?
Tire Size / Transmission gear ratios etc all have to be factored in along with the rear differential ratio.
8L90 has a final drive (8th gear) ratio of .65 where the 6L80 has a final drive (6th gear) ratio of .67
Using an online calculator
2017 6.2 8spd with 285/45R22 32.1 dia tires and 8L90 final drive ratio of .65 to 1 the RPM at 70mph figures out to 1538 engine RPM
2016 6.2 8spd with 275/55R20 31.9 dia tires and 8L90 final drive ratio of .65 to 1 the RPM at 70mph figures out to 1548 engine RPM
2014 5.3 6spd with 275/55R20 31.9 dia tires and 6L80 final drive ratio of .67 to 1 the RPM at 70mph figures out to 1689 engine RPM
So the 2014 was running approx 145 to 150 higher RPM at 70mph cruising speed. Maybe that is why it got less mpg? I would guess that another contributing factor was that the little 5.3 did not have the guts to maintain speed without a lot of downshifting. I have never driven a factory vehicle (to date) that I thought had TOO much power LOL
  • Replies 48
I recently traded my 14 double cab 5.3 for a 14 crew cab 6.2. My 5.3 was leveled with 275/60r20. My 6.2 is stock. The 5.3 was definitely better on gas city and highway as advertised. I'd say 1 mpg or more
So, here is what I have found with real world experience... My 6.2 Denali 4x4 CCSB has 7500 miles on it and an avaerage mpg of 21.8. My Tundra that I traded for it averaged about 17. My work truck is a 2016 F150 with the 5.0 and I am averaging about 19.5 over 11,000 miles. I just drove a rental Dodge with the 5.7 for 4,800 miles and got right at 20 mpg. All trucks 4 wheel drive CCSBs. All mpg's are calculated---not what the display says.
And my 6.2 easily smokes any of the others.
Forgot to mention that I took off the Goodyear street treads and replaced them with LT 275-65-20 KO2A's. cost me 1 mpg...
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
