vibration on modified truck
TT32VGT
i have a '17 slt 4x4 z71 that has a 6" fabtech perf kit and 35" wheels tires..
recently took it into a shop.. taking to another shop next time, long story..
i noticed a vibration.. between 1-2k rpms, 40-77mph.. you can feel the vibration in the steering wheel and the whole truck really.. if throttle is held or its on cruise control you can see the rpms jump a few hundred rpm when the vibration comes through..
has me thinking a wheel balancer came off... or maybe its bc i removed the air dam? maybe the engine is getting more air flow now and the tune isnt accounting for that?
thoughts?
If the RPMs are jumping, could it be the torque converter?
  • 1 month later...
I’m abt to take it to the dealership. Def seems converter or trans related
do y’all think it will be covered?
anyone heard of converter or trans issues on the 8spd?
thx
If they can prove the lift hastened or caused the issue, GM will deny coverage. The torque converter shudder is common in the 8 speed. To correct, GM flushes the trans a couple of times, and refills with a fully synthetic fluid.
On 10/3/2017 at 1:12 PM, TT32VGT said:
no v4 was disabled with the tune
Remove your tune before taking it to the dealer.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 805 Guests (See full list)
