1999Silverado Posted July 20, 2003 Posted July 20, 2003 Does a replacement BCM need to match the truck it's going into? Motor, vehicle wise, etc... The reason I ask is because I purchased a BCM from a 2001 Yukon on eBay for my 1999 Silverado. Everything functions, but the truck wont run. It will start up and then die right away (1-2 sec). Any thoughts? EDIT: I put the original BCM back in and it works just fine.
MountaineerTom Posted July 20, 2003 Posted July 20, 2003 Your BCM has to "talk" to your truck for it to start. With the new BCM, the truck has to learn the new password. Here's the procedures for getting that to happen, which was provided to me by one of our mrmbers, Dex857. http://www.graphicresource.net/truck/learn.html
1999Silverado Posted July 20, 2003 Author Posted July 20, 2003 This board is great! I just got done doing that procedure and it fired right up! Now I'm off to set the lock / unlock options... thanks a bunch!!!
RyanbabZ71 Posted July 20, 2003 Posted July 20, 2003 Tom you should have Mervz add that to the guides section if it isnt already
1999Silverado Posted July 21, 2003 Author Posted July 21, 2003 Any thoughts to why my speedometer is pegged beyond the 100mph mark? I'm going to disconnect the battery to try and reset everything see if that clears it up.
BlackSilver Posted July 21, 2003 Posted July 21, 2003 Any thoughts to why my speedometer is pegged beyond the 100mph mark? You need to slow down, boy! Take your foot off that right hand pedal!
MountaineerTom Posted July 21, 2003 Posted July 21, 2003 Tom you should have Mervz add that to the guides section if it isnt already That would be a good idea to have those procedures a little more handy.
99-2door Posted July 21, 2003 Posted July 21, 2003 Any thoughts to why my speedometer is pegged beyond the 100mph mark? I'm going to disconnect the battery to try and reset everything see if that clears it up. Why are you replacing the BCM if the truck will run?
1999Silverado Posted July 21, 2003 Author Posted July 21, 2003 Any thoughts to why my speedometer is pegged beyond the 100mph mark? You need to slow down, boy! Take your foot off that right hand pedal! BlackSilver, LOL! I didnt think of it that way... I do have a lead foot most of the time though! QUOTE (1999Silverado @ Jul 20 2003, 08:34 PM) Any thoughts to why my speedometer is pegged beyond the 100mph mark? I'm going to disconnect the battery to try and reset everything see if that clears it up. Why are you replacing the BCM if the truck will run? 99-2door, I replaced the BCM with a newer one that allows me to set the automatic door lock/unlock options. The pegged speedometer must've just been a glitch. I'm guessing that a spike from reconnecting the battery sent it to the 100mph mark. I ended up removing the cluster and turning it around so that the needle went back to zero. Reinstalled and now it's just fine.
GnatGoSplat Posted July 21, 2003 Posted July 21, 2003 Does your CARGO LAMP indicator still work if you turn on the Cargo Lamp? That's one thing I've wondered about, because the SUV's don't have a Cargo Lamp.
1999Silverado Posted July 21, 2003 Author Posted July 21, 2003 GnatGoSplat Posted on Jul 21 2003, 02:27 PM Does your CARGO LAMP indicator still work if you turn on the Cargo Lamp? That's one thing I've wondered about, because the SUV's don't have a Cargo Lamp. I thought about this last night... actually I thought about it NOT working because of it being from an SUV. I am pleased to report that the light still functions and that the CARGO LAMP ON lights up in the DIC! Everything still works just as it should, including the fog lights, cargo light and now the lock/unlock options.
GnatGoSplat Posted July 21, 2003 Posted July 21, 2003 Cool! Now to track down an 02 Escalade BCM or get one of mine reprogrammed to think it's an 02 Escalade BCM.
99-2door Posted July 21, 2003 Posted July 21, 2003 I replaced the BCM with a newer one that allows me to set the automatic door lock/unlock options. That's cool, I wasn't aware of this upgrade.
