Passenger climate control temp resets to 60*
Ianwelch001
2017 Denali, just had it in for an oil change and tire rotation. Now the truck has been shaking at 75mph. Dealer balanced the front 2 tires and problem still exists so they will be balancing the rears as well.
Another issue I noticed was whenever I turn the truck on the passenger side temp is always set to 60*  I can change it to whatever temp and next time I go to turn the truck on its back to 60*  auto climate is not on and this happens whether I have the climate control on sync or dual.
The driver side has no problems at all
  • 2 months later...
Just bought a used 2017 Denali and having the same issue with the passenger temp resetting to 63 degrees on mine. Only way I have found around this is to keep both sides sync'd., but defeats the purpose of dual climate.
Anyone found a resolution to this?
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
