53 minutes ago, redwngr said:
They've been like that on Canadian ones for many years.
I've learned to live with it.  A vehicle without daytime running lights looks unusual around here now.
And of course the auto function will switch the daytime running light to regular headlights and taillights when the light sensor detects dusk (or inside a tunnel)
I've heard that the switch can be taken apart and the spring removed so that the knob will stay in the 'off' position.
Could probably also by the US knob from a dealer or parts house.
I’ve seen the video your talking about but I figure if they won’t turn off when I hold the switch in the off position then it wouldn’t matter if I took the spring out. The only reason I’ve been trying to turn them off is because I’ve been having a problem with the HID’s I’ve installed and I’ve been told to disassemble my DRL’s or just turn the lights off and obviously I can’t do that with my truck. Maybe I should just switch over LED’s and get rid of the problem.?
  • 3 months later...
Just added the diode on my truck and I love it! Great mod!!!
On ‎6‎/‎15‎/‎2019 at 12:51 PM, AX633 said:
Boost auto parts sells a part for this. Simple and works flawlessly
Do you by chance have a link or anything?
  • 5 weeks later...
On 2/26/2019 at 5:25 PM, Swerve-n-protect said:
Ok, just to make sure..... the Diode circled as #1 is for the "fogs with parking lamps" mod and the diode #2 is for the "LED lights in the mirror come on when in reverse" mod, correct??  thanks!!!
Just did this to mine yesterday...  Thanks. Works great...  Although I have the boost fog light wiring  (was installed on another truck before I sold it)  I just used the diode this time around...
And if anyone is curious the speed turtle light flasher module still works with this mod...   https://www.ultrabrightlightz.com/flashers/
I think I can help you solve this problem. Regarding the problem of LED conversion, because we have been engaged in LED lights for many years, we can provide you with good suggestions. Please describe to us in detail the problems you are currently encountering, because Your current question is too general, I cannot know some details. Of course, if you want to replace them directly, you can take a look at our LED grille lights, which may be helpful to you
I have a 2016 silverado ltz just purchased. I cannot get the lights to turn on. I Hit the cargo light switch and the lights in the bed turn on but i cannot get the side view mirror lights to work in park or reverse.  Is there a fuse i could check?
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
