Motofab 2.5 level question
Gingerly
So I want to add a motofab 2.5 level kit on the front of my truck but I'm not sure if I should just get the 2.5" spacer that goes on the strut or the 2" block and 0.5" strut spacer. Not sure if one is better for the truck somehow
I just done the 2.5 Motofab level with 2" rear block. The front is a solid spacer that goes on top of the strut. Great quality kit.6e59e29a0ca5d147dfe604f587902c8c.jpg
Sent from my SM-G955U using Tapatalk
Are those Falken Wildpeak tires?  What size did you go with? They look great!  I also love the clean look with the removed badging on the truck.  I've been debating doing that to mine & after seeing yours I may just to the same this weekend.
I installed the MotoFab 2.5 in front only, great kit, Just follow the instruction don`t take any shortcuts.
They are the Falkens went with the 305/55/20. I love the tires pics don't do them justice they are very aggressive in person for a AT tire. Thanks for the compliment.
Love my falkens 305/55/20
Your the main reason I picked these after your pics and feed back. Thanks
They look awesome and they’re quiet. 25k miles on them right now and still look great!
I have the Motofab 2.5” as well but decided to go with a 3” block to give it a little rake in the rear.
Havent decided on tires yet but I’m going with 20” black snowflake wheels.
  • 2 months later...
Your truck looks BADASS!!! I really like its look. I am considering ordering that same exact kit! How bout a updated review on it now that you've had it a few months? any pros or cons you've encountered yet? do you happen to have the measurements from ground to wheel well on front and back?
No problems at all the tires will slightly rub on the uca at full lock in reverse. I really like the Motofab kit very well made front from ground to center of wheel arch is 39 1/2 and the rear is at 40. Thanks for the compliments I had my tune done yesterday and ordered new headlights and projectors to do a retrofit when it all gets here. Next on list is a cam swap.
Awesome truck man!! it sits perfect! Have you happen to notice any vibrations at higher speeds or noises while turning or driving which were never around before the kit being installed? Let me tell you again, MAD PROPS on your truck! it looks perfect!
None at all just like factory ride is a little stiffer but not bad at all. Thanks again for the compliments.
  • 5 months later...
Just ordered the spacers for 2.5 inch level. For those of you with this set up. How are your CV angles? Ball Joint/UCA? Gap between rubber bumper and UCA?
Thanks in advance!
    Aries68
    Aries68
  • Who's Online   0 Members, 0 Anonymous, 392 Guests (See full list)
