2018 Yukon - Help me understand "Media" function
The best, most reliable, easiest Bluetooth/Pandora connection I've ever had in any vehicle, is in my 2014 Silverado.  Every time I get in my truck, it automatically connects to Pandora, without exception. Very easy, no brainer.
Now I buy this 2018 Yukon for my wife. Salesman says, "This bluetooth connection is much better than your Silverado".
OK.
So I go to "Media" on the GMC Intellilink screen of the new Yukon. Then I hit "Pandora" on my phone.  Everything works great.  Of course, I expected it to AUTOMATICALLY re-connect every time I start the vehicle.
I get back in the Yukon an hour later, and the Media screen comes up, but NOTHING.  I have to go back to my phone and open Pandora from the phone.
So, if I have several short trips, will I have to do this every time?  Is there something I'm doing wrong?
Thanks for the help.
Bill
After messing with this for a week, my IT-expert son installed the "Tasker" app on my phone instructing it to Load Pandora every time my phone connects to Yukon Bluetooth.
Works perfectly every time.
(May seem trivial, but I just don't like messing with phone while driving).
Not a solution for bluetooth, but maybe a 'media' solution.  I have many hours of tunes on a usb and leave it installed in the console of the truck.  Always picks up where it left off, even if I've been listening to the fm radio or sateillite in between.
I like the tiny ones like the Lexar one - no risk of it getting hit and broken off.  Available in 32/64/128 sizes
Can you give me more details on the app? I searched for it and didn't see anything obvious under "tasker" in the Apple Store. I am also annoyed by the failure to connect when I get in the vehicle... it works great about half the time, othe times I reset the radio and then the phone and I'm almost where I'm going by the time I have music.
I think Tasker is an Android app.
I also went with the mini micro usb 128 gig for the media aspect. With that amount of storage you could cruise coast to coast twice and still not here the same thing twice.
Yes Tasker is Android only. Pretty slick app. You can do a lot with it. I'll bet there's something like this for iPhone but I'm just not familiar with it.
Thanks for the follow up, work pays for the iPhone so I'll just keep living with it, I'll get my wife's Samsung set up though. I do have a USB drive with a good amount of music I just need to take the time to organize it, right now it's just a random pile of music when I plug it in.
Truck might be able display and play by artists, albums, genre, etc  regardless of file sort order on the usb.
Something like a 5000 file and 15 deep directory limits.
Might be worth a quick try before spending a lot of time sorting (or make a copy to use in truck will doing the sort on another copy at home)
If I'm wrong about the truck being able to sort, just pretend the random mode was selected:)
I need to do more than plug it in I guess... I'm usually on the go with a 2 and 4 year old. I need to go sit in the truck for a bit I guess. Thanks for the tip!
Has anyone made playlists on a usb stick that work with the system and how did you do it
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 353 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
