46 minutes ago, Donstar said:
I ran the cable passed the firewall to a rubber grommet found under the carpet by the driver's door.  The door sill trim is attached to the cover trim next to the emergency brake.  It all pops off easily by lifting up on the sill and allows you plenty of room to run your wire up to and under the dash and/or to a power source in the left side fuse panel.  I used an aftermarket wireless camera and monitor setup so just needed to use a fuse tap. I suspect your oem camera should have specific plug in or splice type wiring instructions. (?)
No splicing needed for “factory” camera. Just plug in basically for power.
Hi All, I'm a little confused. Is this the Echomaster Intellahaul 19366657 that you have installed? Can this be ordered Thru my Chevy Dealer?
I've already had the echomaster bed cam installed by the dealer and just ordered the front cam with dealer install.
The bed cam was expensive but the front cam is only a $145 dealer install after the $209 front cam purchase.
I used my Chevy points to make the whole deal, with tax, a $150 install.
I'll update when I get it.
The bed cam works great for when I have something in the bed with the bed cover rolled in.
    250.3k
    Griffin Donovan
    Griffin Donovan
  • Who's Online   2 Members, 1 Anonymous, 1,995 Guests (See full list)
