DIY Oil Change Question
1 hour ago, redwngr said:
Clearly the 'oil changer' didn't know 6.2 and 6.0 weren't the same!
Did the paperwork they give you indicate what was used?
Yes it had the 8 digit part numbers. I didn't notice the 8 qts until after I was home. 10 min drive. When I read that they used 8 qts I checked the dipstick and found it way overfilled.  Then I googled the part numbers and found listings for the 0w20 and pf63. Partly my fault for not checking while still at the dealer but you shouldn't have to double check their work.  If I have any warranty issues and have this dealer do the work. I  will definitely have to check what they worked on.  Sadly  that is the way it is  and I hope to not have any warranty ssues
