DIY Oil Change Question
Did my first oil change on the truck today. 2016 2500hd 6.0.
Firstly, damn thing sits about 1.5" too low to comfortably creep around underneath. My wrangler really spoiled me the last ten years.  Another reason to level the truck I guess lol.
Anyway, the oil filter was a pain in the ass with the way it is recessed into the oil pan.  Normally I hand tighten the filter on but with this truck I had to use the filter wrench.  Anyway I'm a stickler for spec's.  Anyone have their manual handy or know what the torque spec is for the  oil filter?  I'm really paranoid I did not install it properly.
Thanks in advance
I always go German spec, make sure you have some oil on the seal, and you'll be good to go.
Sent from my STH100-1 using Tapatalk
Most filters instruct you to turn it "X" amount after the gasket makes contact. I have seen it vary from 3/4 of a turn to 1 full turn.
I just use the longer oil filter.. makes removing it easier as it sits closer to the depth of the oil pan.  Wix 57045, EAO17 Amsoil or PF63 Delco.  The instructions for tightness are included usually on the canister which is usually1/2 to 3/4 turn after contact.
I don't know if torque specs really matter. On my first oil change I almost had to use a breaker bar to get the filter off. Whoever the gorilla is at the plant that puts those on, really cranks them down!
Lots report that problem.
Maybe also because they didn't smear a little oil on the gasket?
I've sometimes found that ones I installed seem to have 'gotten tighter' :P, but never seem to be as bad as removing the factory filter.
Haven't yet decided if I'm going to use the 'included' oil changes.  They weren't part of the program when I last purchased a new HD....I did use the included ones on the 1500's.
I don't know about the new 5.3s but on the older ones the torque for the filter was 30N-m. With clean oil on the seal. And the drain plug was 25 N-m. I would think that the new 5.3s should be the same.
I just changed oil in my 17 today and I used the filter wrench to get it tight again.  No way was o getting 3/4 Of a turn with an oily hand lol.  My old filter I took off was leaking a little bit.. This one won't lol.
Up until '86, the assembly plants were req'd to 'dress' the oil filters. I seem to recall the 2WD C/K trucks got the shorter filter while the 4WDs, the longer. One of our duties in the tool room was adding a 3/8" drive socket to the typical oil filter socket. The operator would install the filter w/ an air tool.
The dealer performed only one of the included oil changes on my 6.0. The put 8 qts of 0w20 and a pf63 filter.  They were chewed out pretty good for that fumble. I drained the oil and added 6 qts of 5w30 and left the filter until the next oil change. They must have used loctite on the filter threads. The filter was so tight  it was destroyed getting it off I  even had to use an air chisel on the edge to remove it. Completely ridiculous. Safe to say not ever going there again.  I do my own changes now pf48 or equivalent... use an oil filter strap type wrench...tighten enough to not leak.
I just run my 2500 up on a couple of HD Rhino ramps for plenty of clearance to change oil, lube front end, etc.   I have been changing oil since the 60's and have never "torqued" a filter.  Heck, I don't even torque diff cover bolts.  Guess I have just been doing this sort of thing for so long I just go by feel.  Never had an issue.  Just simple 3/4 turn after contact.  Same on everything from my cars on up thru my commercial class 8 trucks.   I do ditch the factory drain plug at the first oil change and replace it with a Fumoto drain valve.  Makes things much nicer.
I also am running the longer 63 filter, had problems on the '16 work truck regular cab oil filters, the oil filter land on the work truck must not have been machined flat, had to crank down any brand filter hard for no leaks. Have also bought and will install the Fumoto oil valve on the next oil change.
Clearly the 'oil changer' didn't know 6.2 and 6.0 weren't the same!
Did the paperwork they give you indicate what was used?
    • Sir, economics doesn't have a moral compass. 😉 Just say'n.
    • One would think. BUT....This is what a Google search gives for the GM OLM system:    It doesn't measure oil condition save the highly indirect water temperature. It should measure oil temperature and as we've discussed they are not as closely related as one might assume. The algorithm is based on expected conditions at the end of a certain number of miles or revolutions. And sirs, this estimated value is not tilted in the engines favor. It favors the OEM's bottom line. There are no magical number of miles nor revolutions. No magical time limit. There is only what can be measured directly and only in the broadest of terms would the values used even come close to reality.    It samples nothing. It has no idea where the oil started or where it will finish given the limited values use to create the algorithm. It is just a reminder for the brain dead to do something at some time to keep the warranty in tact. Pure fiction.    Key Factors in Oil Life Calculation The OLM calculates the remaining oil life percentage based on the following factors: Factor Description Engine Revolutions Tracks the number of engine revolutions since the last reset, decreasing oil life with use. Mileage Since Last Reset Monitors the distance driven since the last oil change, capped at 7,500 miles for most models. Time Since Reset Decreases oil life over time, dropping to 0% after one year, regardless of mileage. Engine Temperature Adjusts oil life based on coolant temperature; exceeding 260°F sets oil life to 0%.
    • Towing power and I guess MPG matter that’s why I may end up going with a gear swap as soon as they’re available for this truck if I’m correct
    • If I may, I'd like to post my prediction of the trim levels for the 2027 GMC Sierra, based on what was released/introduced today about the Chevy Silverado.   Using the "Professional Grade" wording already in use by GMC, here are the eight (8) trims I believe the Sierra will offer (comparable Chevy trim in parenthesis): Sierra Pro (Work Truck/WT) Elevation (Custom) Elevation Premium -or- Ultimate (Silverado) AT4 (Custom Trail Boss) AT4 Premium -or- Ultimate (Trail Boss) AT4X (ZR2) Denali (High Country) Denali Ultimate (N/A) If GMC would rather simplify the trim levels, then I predict six (6) with package upgrades in parenthesis: Sierra Pro (with a Graphite package upgrade option) Elevation (with a Premium -or- Ultimate package upgrade) AT4 (with a Premium -or- Ultimate package upgrade) AT4X (with AEV and Ultimate packages upgrade) Denali Denali Ultimate  Let's see if I'm close.
    • I have to believe there are already a bunch of threads on this, but my searches didn't turn up much. While I like the ease of a plugin solution like the Carbyte, It appears it disables the AFM or DFM too, and is not configurable to only disable the auto stop/start. So, I'm looking at the Autostop Eliminator product. I like the idea of it better, but I'm concerned about the install and having to pull so many panels to get it installed. Mines a 2026 work truck, so from what I've read it's a less involved install, but having watched a couple install vid's, I'm still a little intimidated. Might need to buy some plastic trim tools to get it done without breaking or marring stuff. Any experience intalling in a WT greatly appreciated.
