About 2,000 miles ago I had the rear diff fluid changed.  Immediately after that I started hearing a whirring noise coming from the rear end.  Turns out it is the pinion bearing slowly going bad.
One shop wants to change the pinion bearing, another shop recommended I change the pinion bearing, carrier bearing, and the wheel bearings since they are probably worn as well, from bits of worn bearing circulating around in the differential fluid.  There are metal shavings circulating around in the differential all the time, so I'm not to worried about that, just he mileage.
What do you guys think?  Change them all or just the pinion.  Just the pinion is around $700.  Changing them all is around $1,100 or $1,200.  both of theses shops have pretty good reputations.
It is a 2007 Classic with 127,000 miles on it.  A little towing of a 3,000 lb trailer.  Some difficult 4WD roads.  But mostly just driving around, city and highway.  4.8L, 3.73:1 gears.
If it were mine and money was not an issue, a complete overhaul.  The wheel bearings though I would not change if they and the axle shafts were fine.
Change all the bearings.  If you do one bearing for 700, and another goes soon, it will be another 700 and so on.  Do them all and it cost 1200 and you done.  I would even consider a new set of gears and maybe even a new diff, particularly if it's a G80. If the gears look perfect mad still have lash in factory spec, you can skip those.
My vote is change all of them. The price sounds a bit high, though, but that might depend on location.
Sent from my SM-G920V using Tapatalk
I was going to say the same thing. As far as the cost. I did an estimate on our system and this is it. Now we are a dealership and our labor rate is $92hr.
But if you wanted to get it cheaper. I would ask them what there labor rate is and bring your own parts.
Pinion bearing inner - $42 - http://amzn.to/2DiVc4o
Pinion bearing outer - $47 - http://amzn.to/2DitPI0
Pinion bearing seal - $24 - http://amzn.to/2D31amP
Pinion spacer - $5 - http://amzn.to/2D4lrs1
Carrier bearings - $10 each (20) - http://amzn.to/2FzVjHj (these are GM bearings for $10!!!! LOL)
Wheel bearings - $32 each (64) - http://amzn.to/2D1JJTx
Wheel seals - $10 each (20) - http://amzn.to/2DwVGBQ
GM Parts Prices from Amazon - $222
And if they charged $100 per hour at 6 hours $600
And that would be $822 Plus tax with GM bearings (which I believe are the best bearings lol)
Thanks for the input.  I really appreciate it.  Especially the estimate Carnau/Chris.  Sweet!
It's not a G80.  Just your standard 3.73 open differential.  Changed the fluid at 50K and again at 125K.  Not sure why the pinion failed.
V
Sometimes it just happens.  You can do all the proper maintenance and still have issues.  Now might be a great time to add a limited slip like a Detroit true track.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
