Yesterday I decided to go through the electrical system on my truck being it's almost 4yrs old and has 75k on it.  I cleaned up the battery terminals, took the positive battery distribution system apart, even took the hot wire off the alternator.  Everything was cleaned, sanded with 320 sand paper, cleaned with electrical parts cleaner and put back together with dielectric grease.  I'm glad I did this job because the stainless steel connections were starting to gall and it was extremely hard to remove the nuts.  I was scared of snapping the stud off the alternator I used a pry bar to hold the wire lug in place while loosening the nut.  I then followed the smaller ground wire from the battery to the passenger side chassis ground.  Took it apart, clenaed the frame, wire bolt everything up.  glad I did.  the frame coating was in the way and hte wire connection was corroded pretty good.  Again, everything was sanded, and cleaned with electrical parts cleaner and put back together with dielectric grease.  Then wiped clean and sprayed with battery terminal protector spray.  There is another ground wire on the driver side, behind the front wheel.  Did the same thing to it.  It also needed it.
I checked the entire frame for more connections and could not see any.  Now my High SWR readings from my CB antenna mounted in the middle of the roof make sense! There is literally no ground wires from the frame to the body anywhere except under the hood.  By the brake booster there is a ground strap going from the fire wall to the block.  I am going to add some ground wires, connecting the body to the frame.  I'm thinking adding grounds from the frame to both the bed and box, right behind the cab, on both passenger and driver side. And adding a wire from the engine block to the firewall/fenders.
You take incredible care of your truck!  I understand your rationale for adding grounds but I approach this a little differently.  Your bed and cab are grounded to the frame through every nut and bolt but some parts seem to make lousy grounds.  Whenever I've added an electrical component to an aging vehicle I simply run a desperate ground wire.
Edited by Donstar
Update. Today  I found a frame ground on the driver side, behind the cab.   It's a ground wire on a bed gusset.  Wire runs from the frame up to the gas filler neck area.  I took that one apart at the frame and cleaned the heck out of it also; removed the frame coating and sanded it up nicely.  I made a 10ga wire that goes from that frame bolt to a bed mounting bolt about 6-8" away.  Under the hood I made a 10ga wire up to go from the front of the driver side valve cover area to the LF fender by the fuse box.  I plan on making one more and running it from the battery neg terminal to the RF fender.  Calling it good.
Tell you one thing, so far since I've done my ground and wiring connection cleaning, my horn honking while locking is back to working!!! For the past 2yrs when double pressing the lock button to make the horn honk, it would 90% of the time not honk.  Or you had to press the button a million times for it to finally honk. I think the grounds were affecting the horn on short honks like when locking.   I have yet to have it not honk while locking since the ground cleaning.
My CB antenna is mounted on the right side bedrail, and has a high (2+) SWR.  I'm thinking it's because of the mount isn't ground to the vehicle very well, doesn't have a good ground plane, and I'm looking at going dual antenna to hopefully lower my SWR, even more than grounding my mount.  I'm trying to find a good ground on the right side of the bed, have you found one, other than the filler tube on the left side?
Have not found any other bed to frame grounds other than the fuel filler neck.   Again, I added my own bed to frame ground strap, sharing the frame bolt for the fuel filler neck ground.  My headlight flickering BS is also fixed.  So now the truck honks when I lock it and the headlights don't dim with the blinker.  Curious to see if my SWR's are lower now.  I still plan on running a ground wire from the battery negative terminal to the passenger side fender.  know where I got that idea from....  Looked at the grounds on my '89 K5. It has a 10ga wire going from the neg post to the passenger fender along with the main wires to the block and frame.
Edited by FL335i
Come to find out, I put the antenna on my mount bracket incorrectly.  My bracket is getting a great ground with the way it is mounted to the bedrail, especially as long as the "gasket" is on top, between the top of the bedrail and the mount bracket.  Meter SQUEALED at me checking the ground between the mount bracket and the right rear door catch.
As stated elsewhere, bed is grounded through all of the nuts/bolts.  The fuel tube ground is for the fuel going into the truck.
Antenna grounding has little to do with electrical grounding...
2012 2500hd 6.0l CCSB 4wd
They still get grounded to a vehicle ground.
Edited by Ravenkeeper
Firestick is the probably the worst resource you could quote.
An antenna needs two things, a poise and a counterpoise... it can be completely isolated from the vehicle ground. If what you want to believe was true, the how would a base station work...
I'm done here...I have nothing to prove.
Not just Firestik, but several (if not all) other CB antenna sources out there, all state that your mount needs to be grounded.  Magnet mount antennas get "grounded" through the shielding of the coax, back to/through the radio.
And to answer your base station question, YES, it gets grounded too.
And like you, me and my 30+ years experience are done.
CB Antenna Ground:
https://www.wearecb.com/testing-cb-antenna-ground.html
https://www.rightchannelradios.com/blogs/troubleshooting-guides/18428219-testing-for-a-ground
https://www.thetruckersreport.com/truckingindustryforum/threads/how-do-i-ground-the-antennas.146708/
Base Station Ground:
https://itstillworks.com/ground-cb-base-station-antenna-2923.html
https://forums.radioreference.com/cb-radio-forum/348744-cb-base-station-antenna-grounding-question.html
Well, I've seen guys with 60 years of radio experience that don't know the difference between electrical ground and signal properties.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 283 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
