2018 silverado tailights into a 2017
dgoodal
Hello, I have tried called my local dealerships parts department and cannot seem to get an answers so I thought I might have better luck here. I have a 2017 silverado but I think the tail lights on the 2018 look way better. will the 2018 tail lights swap directly with the 2017?
any help is appreciated
it's not just a 18.   Is the 18 a LTZ?  That's the only different light.  Work trucks all the way to the LT use the same light.  LTZ have LED tail lights.  14-18 all fit the same, with the LTZ being the exception.  You'll need a custom harness with load resistors to make them work, but they'll fit right in.
any suggestions on where I could get that harness or load resistors? my two trucks before this were a K5 blazer and an 04 tahoe so I have no experience with changing out lights or electrical
Gen5diy has them.  Also I think a member on here makes the harness.  His name is @pgamboa I would send him a message before you order from gen5, not that there is an thing wrong with them, would just prefer to buy from a fellow member.  He is on vacation for a couple more days so don't worry if he doesn't get right back to you.
http://www.gen5diy.com/Chevrolet/Silverado/LED-Taillight-Harness9/
Load resistors can be bought anywhere.  I got mine from Amazon.  100w 3ohm.  If you get the 3 ohm, you only need one on each side.  If you get the 6ohm ones, youll need one on each bulb.  Two per side.  Twice the cost, but can be done.
https://www.amazon.com/Cutequeen-Aluminum-Wirewound-Chassis-Resistor/dp/B01N0XZTGB/ref=sr_1_1?ie=UTF8&qid=1519688235&sr=8-1&keywords=100w+3+ohm+cutequeen
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
