New member from Toronto
Hey everyone!  Just registered this morning after reading hundreds of posts here when I was going through the conversion from DL3 mirrors to power folding camper mirrors. Also following the levelling kit topics since my truck is getting ready lift 2 1/4” front levelling and 1 3/4” rear lift blocks installed on Saturday (changing to GM aluminum upper control arms up front just to be safe)
Been a GMC guy all my life, first truck was a ‘05 Sierra 1500 ext. cab with lots of mods, now driving a 2016 Sierra 1500 SLE crew cab All Terrain which I’m slowly doing pretty much most of the same mods to.
Welcome and good luck with your mods.  The level and mirror modifications are very popular with these trucks. Researching on this forum can save a lot of time, worry and money. If you're switching mirrors and haven't come across pgamboa, then you need to do more reading!  He will make the transition painless for you.  Also, two years ago my levelling plans were similar to yours.  Level headed GMC-AT gave great advice on this topic.  His advice and further research convinced me that a 1.5" front level will give the look I want, maintain some rake, easier on front end components and  inexpensive.
Thanks Donstar!  I read up on pretty much every post regarding the mirrors once the swap became a clusterf**k at the dealer. They originally installed the “accessory” mirror kit thinking that it would give me power folding. I had to show them a bunch of posts from here to prove otherwise, along with input from another dealer that ran into this problem on someone else’s truck. They installed the correct factory power folding mirrors last night, I only paid the difference in parts which I thought was fair. I considered 1.5 levelling for the front, but decided to go with the 2.25 ready lift kit because my truck lives on construction sites all day, any little bit of altitude helps. I would’ve loved to do a 4” lift but couldn’t come to terms with having to cut or even notch the rear cross member, and I really want to keep my stock AT rims
  • 1 month later...
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
