Not your typical AFM issue
So I'm on my second 2014 5.3 truck first one was a Silverado that I started the Shake or Vibration topic post that I got rid of for a 14 Sierra. I'm very familiar with the how some times the transitions between v4 and v8 or vise versa can be not quite as smooth as I would hope and some are so smooth it's almost undetectable. Put about 13k on my Silverado and 54K now on my Sierra so I have a pretty good idea of what has been normal up to this point. Past few weeks at about 68 mph I will go from v8 to v4 and back to v8 all within a second. started out once every few days and now it happens once a day it seems. One day it did it 4 different times within probably 2 miles. Has done it with cruse on and off. When it does it, it gives the truck the feeling of bang,bang, bang all in about a second time frame. 2 times now it has felt like it's got hung up between the modes, it took about 3 seconds to change over like it stuck doing the switch over. Ive never been really happy with how it feels when it switches over but this is something totally different. Whats going on that's making it do this? Is it damaging the motor when this happens? I have warranty left but no check engine lights so I'm sure I'll get the "couldn't replicate" answer if I bring it in. Thanks.
Johnny01: I have a 2016 Silverado with only 5000 miles on it.I've had no problems with this issue. But if your truck is having this issue it could damage your running gears. I saw a video on YouTube that shows you how to disable the V4 and run only with V8.
Sent from my SM-G935V using Tapatalk
Can't say I've had that exact issue but out of curiosity are you starting to near your oil change interval? Since these ecotec3 motors all use the engine oil moving through tiny passages to activate and deactivate AFM I have found that once my oil starts to get "used" the afm becomes increasingly rougher in transition. I have found switching from the ac delco semi synthetic a quality full synthetic helps significantly. Perhaps if not already doing so you could give that a try and see if the condition improves?
I'm familiar with the keeping it in manual 5 gear so it can't go into V4 but because of the speed I drive I run at 2500 rpm in 5th so that won't work for me. Also know about the Range programmer that keeps it from going into v4. I don't want to the Range if there's something going on that would make the Range act as a bandaid to mask an issue. I have a feeling it's possibly a solenoid for a lifter that's going out. Id hate to have a breakdown while still under warenty and have the Range detectable and have a claim denied. I think I've read the Range isn't detectable once you pull it but still think it's a bandaid for the issue I'm having right now. If I find my issue is something easy to fix I'd probably get one after my warenty in 5500 miles.
I'm right at 50% when I looked today. Last 3 or 4 oil changes have been mobile 1 full synthetic  Dextos compatible.
Dealership.    And get the documentation that you’ve had the issue addressed while it is under warranty coverage.
You search TSBs?
You search TSBs?
I've looked online for a website that would let me search for tsb on my truck .  Unfortunately I'm not having any luck with finding anything that gives me more than just what my outstanding recalls are.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
