So couple days ago my left rear turn/brake started acting up. I get the left rear indicator failure message. The bulbs are fine, I checked the fuse and its was good too. I went ahead and got a new fuse and bulbs and installed them, yet nothing. With a tester I tested the power coming from the BCM thinking it went out but no power comes out. I tested the fuse also and it lights up/flashes when the turn signal is on or step on the brake. I checked the entire harness and there were no signs of cuts. Here is the weird part this shit will work when it wants. It can be fine for two days and then the next day it wont work and will last until it decides to work. So II was thinking it was a relay when it gets hot it wont work. As it cools down it will start working again until it heats up or bullshit like that. That's my only solution as of right now. Does anyone know what relay it would be? OR WTF is could be? The right side works fine all the time. I shared a pic of the wiring diagram to give a better example of what I'm saying.
THANKS FOR ANY HELP!!!
It may be a bad socket connector on the end of the harness Had an issue like that on a 05 Colorado. Had to replace them..
  • 1 month later...
The first thing that came to my mind was a faulty ground.  It sounds to me you have already gone above and beyond the steps needed for a DIY solution.  Go to a gm service facility that you trust and get it checked out.  You  may be missing something simple and obvious to someone else who is able to physically see your vehicle.
A good example of my advice recently applied to me personally.  Last week I was out in my brand new Winnebago TT and  I could not get the park's cable to work for my TV.  I asked for help on a Winnebago forum and traced all of the wiring.  I even phoned an RV service department.  Two days later I explained my problem to the park owner who was very knowledgeable on the topic.  The first words out of his mouth were, "you need a cable box."   This sounds obvious now, but it was totally out of my realm of consideration that you'd need a home-style cable box at an RV hookup!  Nobody on my RV forum or at the RV dealership even hinted at a cable box!
  • 11 months later...
Yeah dude I'm having the same problem with my truck but now my tail light went out all together with two brand new bulbs so something in the wiring or my sockets. Cuz when I replace my top tail light the sockets were so corroded I couldn't get the light bulbs out but now left turn signal failure. Is on all the time.  So it's got to be somewhere in The wiring.  Or bad relay some where
  • 4 years later...
I have been battling this issue and found that the problem is with the metal contacts on the bulb itself. They lose contact over time. Take the bulb out and bend the two natal contacts out slightly and then reinsert. I hope this works for you too.
    250.3k
    user087
    user087
  • Who's Online   1 Member, 0 Anonymous, 890 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
