My 2017 rear driver door lower rear corner was just like the pic.  The dealer replaced the hinge bolts and its almost perfect, said they installed wrong one on assembly line.
  • 5 months later...
Hi guys! I just bought my 18 Sierra Denali 2 weeks ago and I just noticed the a gap between the drivers door and rear passenger door. Is there any update on a fix? I contacted my dealer and will be bringing it in on Monday. After reading previous posts I had to take another look at my truck and noticed more misalignments. I found the rear right passenger door bottom, the left rear door, and the top corner of the driver door issue. I know its dirty, it's been raining nearly everyday here in Chicago.
On 4/23/2018 at 1:01 PM, ChristopherDB said:
Has anyone had issues with any body panels not aligning properly?
My rear passenger door is popped out a little towards the bottom, but everywhere else on the door is perfect. I really don't think this is an alignment issue, I think the door is bent. The dealer looked at it and put in a claim with GM and the collision department will be looking at it next month. Service department told me "it's a truck, not a Lexus" which I told them that is not an acceptable excuse for this.
And the left side of the tailgate is not flush. I tried bringing the tailgate post in closer towards the cab which didn't help because it would not engage the latch.
17 hours ago, Joys said:
My rear door panels are the same way and I've noticed in vids on the newer models, as well.
However, my tailgate is correctly aligned.
Might need a slight adjustment?
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 306 Guests (See full list)
