My truck also has an misaligned right rear door. My dealer said they would fix it. I walked the lot and 80% of the new trucks has a misaligned right rear door to some degree. 50% of all trucks had a misaligned that I, as a consumer, would laboe as unacceptable.  I will update after the dealer repairs it. I am thankful the dealer is trying their best. This is a manufacturing problem that they, or me, should be having to deal with.
I have a 2017 gmc and a 2018 Silverado, my Sierra is perfect and my Chevy is shitty.d6f17e56c4cc43d103d7704ae3cd7960.jpg
How the factories works to save time and money is they will let standards slip and go from 4mm to 8mm out if people don’t take their vehicles in and complain.
  • 1 month later...
Any resolution to this? Have had my LT Crew for about 2 weeks and noticed the same gap on the right rear door at the bottom. All other doors sit better. Trying to figure out what the dealership would do to make it look flush.
No perfect resolution. Dealer adjusted the door so it is slightly better but any more adjustment and the door would be too far in at the top. Dealer showed me a bunch of new trucks on their lot that had the same issue so I gave up. Same thing with the tailgate not flush on the side. Almost every truck I looked at had this issue.
6 minutes ago, SilveradoGraceland said:
Going to go to dealer tomorrow and see what they suggest.
Keep us updated!
Went to two dealerships and spoke with their body shops. Both recommended that they can manually twist or bend on door to get it closer. One said it’s pretty common for them to do that. Not sure I’m willing to go that route. May just live with it since they said it won’t effect the interior of the cab (weather, wind, etc)
I wonder what the process consists of and if there are chances of damaging the door. I'd be worried.
Went to 3rd dealership body shop and they are going to put new bolts in rear door hinges. They said they have done this to several Silverados and Sierras and it makes it noticeably different. They even said they would paint them which is a nice gesture. Thoughts?
  • 4 months later...
What was the outcome? I’m going through this with my dealer, both rear doors not aligned also bed off to the drivers side.
I work at a paint and collision shop. Yes, Chevrolet has a lot of alignment issues straight from the factory. Especially with the rear doors at the bottom. If you think these have issues, you should see Ford body alignment issues. They are way worse. Brand new vehicles shouldn’t have these problems. That’s what happens when vehicles are assembled in Mexico. Poor quality control. For the Silverados, fixing that lower rear door requires a lot of twisting in the door. Almost to the point where you could cause damage to paint. When we come across the problem, the truck usually needs repaint in that area so we can really bang and twist on the door to get it almost perfect. My 2016 Silverado has alignment issues all over the place. I just drive it and enjoy the ride. Like the post above says: it’s a truck, not a Lexus. Don’t expect American made vehicles to be perfect. Cause they’re not American Made anymore.
Well, mine are good but I have "tweeked" several doors over the years...last one was a 2008 Avalanche. Had some wind noise from the drivers window area...lowered the window, open the door, put your knees on the door and GENTLY give a few tugs to the top of the window frame...test drive and repeat as required but it's worked every time. The trick is to not tug too hard the first few times and do it gradually. No more wind leak sounds. Have no idea how to fix the bottom of the door.
Edited by SS502
That's ridiculous.  I expected and got perfect panel alignments on my American built Silverado. For over $50k, I wouldn't except anything less.
On 4/30/2018 at 6:12 PM, TECH12 said:
I have that same gap on my rear door. The two rear doors do not shut easily. Everytime I close it without thinking about it the door doesn't shut completely. I took it to the dealership and they said that's how it's supposed to be. I'm going to another one
My friend had this issue on his 2018 Sierra. The cause for him was that he put one of those storage bins that are made to go under the back seat. With the seats down, they pushed on the bin a little which in turn flattened out the GM all weather mats causing the rubber to push out slightly making it a bit harder to shut. I think he ended up trimming the mats.
    ncleg
    ncleg
  • Who's Online   6 Members, 0 Anonymous, 744 Guests (See full list)
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
