Anyone have a good way to enable video in motion.  I have movies on a flash drive and can play them on my i05 radio but only in park.  I remember back when I had a double din head unit in a old truck you could just put a ground wire to the "parking brake" wire and everything would work.  They sell modules that will do this online, but there has to be a better way.
Selling my video in motion bypass. 10 min install asking $100.00
32 minutes ago, Viktorrocks15 said:
I ended up unlocking my HMI so I don’t longer need this to play videos for my kids.
How do you unlock it?
  • 3 years later...
Still have this? Kinda going out on a limb but gotta try. Let me know!
Yeah, as mentioned in the post above you, with the item mentioned, it does work.
I was asking if he was still selling his harness or if it was already sold. Do you have one for sale?
Well, since he posted 3 years ago, I doubt he still has it but, indeed, it's worth a shot.
However, video in motion doesn't require a harness, just an Autosync and a BTDiesel HMI unlock.
Check out WAMS for details:
https://www.whiteautoandmedia.com/
Thanks…
  • 9 months later...
This is pretty cool but if you choose the G2 option what is full unlock given you? Since gm disabled playing video from USB on 2017+ is this checkout price right?
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
