Break-in procedure for a new engine
I just picked up a new Yukon XL 2003 with a 5.3L engine and the luxury package. Cannot wait to start working on it :cheers:
What are the DIY service items that are recommanded for an engine's break-in period?
Change oil after a 1000 mile?
Are anything else recommanded?
I myself usually change the oil and filter within the first 250-300 miles. There's the assembly lube on the cam that's been washed down and the miscelleanous sand from the engine block casting and some very very fine metal from the initial friction. The first change is to synthetic and run to 1500 miles then changed again at 3000 miles then again at 5000 miles along the with transmission, differential, power steering. Them my standard maintenance schedule of oil and filter every 5000 and transmission, differential every 15000. Coolant, brake fluid flush and powersteering flush every 25000. All synthetic service. It's all extreme aggressive schedule even for a daily driver in the desert, but I haven't been stranded by any of my vehicles of past that were had new and followed this procedure by a mechanical breakdown, just by electrical (harness melting) ignition modules bad in flight, the desert heat ridden battery, the overworked alternator and the slightly overlooked coolant hose.
Follow the manual about varied speed 55 and under and no WOT, for the first few hundred miles.
That's good advice on the conservative side. I've read plenty of posts saying break in an engine hard. One if it does break, that means it wasn't put together "good" in the first place and would be covered under warranty. Two, you will get the pistons to seal better for more compression and power (and less likely to get blowby/oil burning) Always make sure it's warmed up before pounding it. The few cases of friends doing this had these results (1 guy with a dodge had a bad engine leak at 10k) Two other chevy's were hard running afterwards. Main thing is to change the oil soon after doing this because it results in more shavings faster. Here is a link for break in secrets
you be the judge. My gf and I plan on getting identical trucks and trying both procedures to see what works best in the next couple of years.
I agree, it is all a matter of what makes you feel better, follow the owners manual or go with what others have done and had great success. The previous posts are dead on with the fluid changes. Synthetics or not is up to you also. If you have the cash and want the added benefits of synthetics then go that route. If not then oil changes every 3k with regular oil will serve you just fine.
I've always broke my new vehicles in by driving them the way I would if they were already broke in. Never had a problem with them and the most miles I have had on them before I traded was 125k with no problems.
Read up on here all you can and then go with what seems right to you.
Congrats on the new truck, It is a great feeling owning a new vehicle. :cheers:
Drive it like you stole it for the 1st 2500 miles. For an engine to seat properly you have to generate heat. Drive it hard then drive it kind so it cools before shutting it off. Use dino oil for first 12K to seat engine then go synthetic. I use the internal clock to do oil changes since I use synthetic oil, if you use dino oil every 3K is very popular. Synthetics often lubricate to well to let the rings seat right. After 2500 miles drive like you normally do. My 2 cents. Good luck! :cheers:
    250.3k
    TheStranger
    TheStranger
  • Who's Online   5 Members, 0 Anonymous, 1,687 Guests (See full list)
