Old thread revival, but did anybody ever find the side pieces separate from the complete part? I can't find them either. I would even do vinyl stickers if I could find them in matching synthesis grey.
Those pieces are not serviced. Need to buy the whole tray.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
