GM Extends Military Discount To 3 Years After Discharge - Details
John Goreham
5-25-2018
General Motors announced Wednesday that all four of its brands — Chevrolet, Buick, GMC, and Cadillac — will extend their military discount to members who have been discharged as recently as three years ago. “Supporting service members and their families is truly part of our fabric at GM,” said Steve Hill, vice president, U.S. Sales, Service and Marketing. “Extending the discount to three years post-service allows military families to settle back into civilian life and take the time they need before purchasing a new vehicle.”
The overall program remains the same: Soldiers and sailors, as well as members of their immediate families, qualify for a special discount on new vehicles at participating dealers.
GM employs more than 6,000 veterans — To find details on all the newly extended military discount please visit the GM site here.
Yea but you don't really get it.  I just bought a new 2018 GMC Sierra over Memorial Day.  I watched the salesman put a check in the box for the military discount and it did not change the price at all.  I did get a Memorial Day discount like everyone else so thank you for that.  But there was no Military Discount for my 23 years service.
I still like the truck though. :)
While a good jester it is cheaper to not us the Military discount. Same goes with supplier pricing. Much better deals out there taking the huge discounts and rebates open to all.
    • 286,740 Mile Services   8/6/2026   New AC Compressor. Refrigerant oil and dye, evacuate and charge system.  New exhaust system from cat back.  New Iridium plugs plus replace #3 coil Repair/rewire headlamp wiring (passenger side) and replace all forward bulbs. Polish lenses of both assemblies.  Pull rear rotors, clean and adjust parking assembly. Inspect, clean and grease front calipers. Check pads and shoes.  4 wheel power bleed of brake system. Dot 4 Reset idle speed 50 rpm higher New Serpentine belt.    Will need new pads in the rear in about 5K more miles.    Tax Title and License out the door just short of a grand.    AC clutch had bitten the dust. 1 year warranty on the pick and save replacement. Thing will make a Polar Bear cry Uncle.  He spent quite some time on the wiring. It was in the harness and he does nothing half. I got off cheap. I have considerable more light down the road. Sylvania Silver Star replacements.  Gas seal between the porcelain and shell of plug #3 was blown, cooked the coil. That was the cold miss.  Love the new exhaust. I can sneak into the neighborhood again.    This was one of her bigger bills and still way cheaper than a payment even given the oil consumption. This thing cost me under a hundred a month in repairs and normal routine costs. What is my incentive to replace it? 🤔
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
