2018 Sierra tpms programming
I changed my wheels on my 2018 Sierra and I Just wanted to let everyone know that the el-50448 tool works to program the sensors. I bought the cheapest one on amazon and it worked perfectly.
  • 2 months later...
did you install  new sensors, or just reprogram your originals?
I am looking to get another set of sensors to put in my aftermarket wheels. it would be super convenient if I could just use a TPMS tool and reprogram based on which set of wheels I have on the truck
On 9/7/2018 at 8:49 PM, mopac said:
Was it https://www.amazon.com/VXDAS-EL-50448-Pressure-Monitor-Activation/dp/B072BK693N/ that you wound up getting? I just bought a 2018 Silverado and read in this forum about the need for one of these tools when it comes time to  do the tire rotation.  I expect if what you bought works for the 2018 Sierra, it will work on my 2018 Silverado.
That is a similar one mine was green but same model #.
The new rims have new sensors so it works on both.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
