Looking online and can't seem to find them. I think GM started adding them in 2016 maybe? Anyone have a party number or source? 63e92ec3a5cbb4b02aa8682d666b5cc2.jpg
Sent from my SM-N950U using Tapatalk
There’s a TSB for these on the 14-15s if you can get your stealership to do it. If not they are cheap enuff off EBay (30ish a set) and install them yourself.
  • 4 years later...
