On 8/10/2018 at 8:09 AM, TJay74 said:
The local station that has E85 on the pump is not consistent, they range from E65 to E85 depending on the time of the year. The last modifier table is at E80, so as long as you are over E80 will be getting the max tune changes possible.
I have the same problem getting higher ethanol %. You can rescale the column axis on various flex fuel tables. For example I have mine set up to give full timing advance/****** at 65% alcohol.
11 hours ago, nbennettksu said:
Thanks! Just ordered everything I need :D
You'll have fun! It's a noticeable change even on the OE tables, which I've learned aren't that great. The torque increase is just ridiculous.
