Electrical issue
Jpaz
Hello all new to the forum. So I have a 2016 Sierra the other day my wife was helping her sister jump start her car well they hooked up the cables backwards first it wouldn’t start up and all the lights were dead inside, I replaced the large multifuse at the battery with a good used one. The truck started up after that but since then I have no electric steering the interior lights dnt work, the backup sensors have some kind of error and the puddle lights stay on. Not sure where to start any help would be greatly appreciated!
I actually removed the battery when I  replaced the fuse I left it out for a few hours and that didn’t help
I would start with checking every single fuse in the truck. Your owners manual will list the locations of them all. Then I would check all the fusible links (if there are any). After that, I would buy a handful of relays and start swapping them out and switching around ones that have the same part number.
If none of that is successful, you are running low on options. I suppose its theoretically possible that the battery was damaged in some way. You might try swapping it out for another one that you have laying around.
Beyond that, you probably damaged some wiring or a circuit board. If your not getting any OBD2 codes, you will need it take it in for a diagnostic.
Also, I'm sure that you already know this, but for those of you that don't: Car batteries can explode. They can be extremely dangerous if they are not handled properly. I would say that your wife is very lucky that she did not get blasted in the face with shrapnel or sulfuric acid. The acid can dissolve your eyes in 30 seconds, causing permanent blindness. Some damage to the wiring on your truck is a very small price to pay for that mistake.
Here is a link that may help you resolve the problem with the vehicle:
https://drivinglife.net/what-happens-when-you-jumpstart-your-car-the-wrong-way/
I checked all the fuses under hood and inside they are all good that’s why I’m stumped on why things like the dome lights aren’t working. I will try the relays out next but not sure on fusible links without a wiring diagram and yes she is very lucky that didn’t happen
The puddle lights staying on bothers me more than anything, that suggests a meltdown and short internally in a fuse block. After all fuses are checked and "double checked" your only choice will be to pull the fuse block and check the back side for meltdown issues. The reversed connections must have been for more than just a few seconds!!
Not sure exactly how long but it wasn’t long at all the arc scared her and she called me, I will check the fuse box a little later today see what I come up with
But even then not sure how that would take out the steering
   If you have electric steering, it could be a fuse or other wiring issue. If you have hydraulic power steering, then it could be one of the fluid pressure sensors.
It’s electric steering but I dnt see a specific fuse for the electric steering
I would think that your steering system would have a direct link to the battery, so that if the engine stalls - you don't suddenly lose your steering assist. I doubt that there would be any voltage road blocks like fuses or fusible links to protect the system. I have no idea how your steering system works though. I have only worked on manual and hydraulic systems.
Yea that’s what I’m trying to figure out but without a wiring diagram it’s a little difficult
  • 2 months later...
So I figured I post an update for future reference to anyone the lighting issue was a bad bcm and the rack did burn up in the process of the battery shorting. It’s all working good now
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 757 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
