You can tune the fans with HP Tuners,  https://www.hptuners.com/product/mpvi2/  .  However, it really shouldn't be needed in your case (with that sized trailer, highway towing with no mountains) and probably not worth the possible warranty issues of a tune just for that, unless of course you just want to.  Your truck really should be fine as is, I'd expect max temps around 200 degrees, maybe a bit more.  I do believe such temps with modern fluids are nothing to worry about--but don't like it getting much hotter than that.
However, there's nothing wrong with lower temps and it can give you a lot of peace of mind to stay way, way out of the danger zone.  If you want to do that, all you need to do is bypass the stock thermostat which can basically be done for free.  Your stock cooler is big enough it's capable of keeping the temps much cooler, especially on the highway.  I usually do recommend adding an aftermarket thermostat as well, but in the south as you are it's not a real high priority and is a lot more work, you could just run with the stock bypassed for a while and see if you feel it's needed.
I'm currently running an aftermarket 140 degree thermostat using the air/oil condenser cooler only, and that setup has dropped my average temps 30-40 degrees from stock in light to moderate use on the highway.  I haven't done any heavy towing torture tests yet, just some light towing, I expect during heavy towing the advantage to be greatly reduced but still beneficial most of the time.  I'll be hauling a pretty heavy load over some big mountain passes in a couple of weeks so I'll have more insight on how the setup does in those conditions soon.
  • 2 months later...
  • 1 year later...
On 8/13/2018 at 4:35 PM, Jon A said:
Yup, that IS your auxiliary cooler.  It's actually quite big for a 1500.  You have the best transmission cooling available on these trucks.  You'll be fine.  If you find you want even cooler temps, bypassing/replacing the thermostat with an aftermarket unit makes a big difference and tuning the fans to come on earlier helps as well, especially at low speeds but I doubt you'll find any of that necessary with a trailer that size.  Is most of your towing on the highway or is a lot of it on slow gravel roads, etc?
Thanks for posting that parts diagram.  I did not know they did that.  It's likely the main reason some users of newer trucks have reported better performance (cooler transmission temps) than the older ones.  If I had posted my rants on how dumb it was for GM to put an in-tank heat exchanger in the hot side of the radiator a couple of years ago, I might accuse GM of listening to me.    :lol:    Again, so there's no confusion, it's no loss.  I have mine bypassed and the trans runs cooler for it.  In all but very rare conditions, that radiator tank exchanger acts as a heater, not a cooler.  And since we have a thermostat, the heating function is worthless at warmup anyway making it pretty much worthless all the time.
Did these changes happen for MY14?  Interesting and great ideas.  Is the in tank exchanged on the drivers side of the rad?  Need to go have a look at my truck once it stops raining.
  • 1 year later...
  Hi there,  I was planning on putting a plate/fin after market cooler inline to add some additional cooling.   Can you give me some more information (link if possible) on how you bypass the stock thermostat?  Or adding and aftermarket?   I have a 2018 sierra 1500 5.3 L.  thanks for any help.
    whenindoubtuseahammer
  • Who's Online   0 Members, 0 Anonymous, 290 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
