Android Auto Issue
My dealership that I just bought my 2016 Sierra 1500 SLT from is claiming that I have the latest update to the HMI or Intelilink System, however, I have apple car play but no Android Auto. None the less I was not able to get android auto to work... only a data connection to the phone. The dealership claims all of my software is up-to-date and they were able to connect a android fine, and that is must be my phone...... so either they updated it and they are not admitting it, or they are not telling the truth and it still does not work..... Either way my phone connects to android auto just fine in the loaner that they provided me with.... so its not my phone or cord.... Can I get a couple people to tell me what your software version lists? Mine says Software: 23415881 and I only have the option for Apple Car play in the settings also. I have scoured the search and google and have not found a revision list but if that it available that would be awesome!!
Thanks ahead of time!!!
Have you tried a different android phone in your truck to verify that it’s not your phone?
You have the ‘projector’ icon on the intellilink display?
Ask them to show you that it works if they said they tested it.
Some late built 2016's are not capable of android auto, due to a hardware change.
In about March of 2016 the software update became available for early production 2016 pckups.
IIRC, the build dates were about may of 2016, and it was specific audio system version that could not run AA.  A credit was applied to these trucks, as the 2016's had been advertised as being AA ready (meaning when the software update was release).  There was an RPO code associated with the credit, and there was no 'factory' upgrade path available.
Not sure if that's what's going on with your truck, and if so, not sure why the dealer wouldn't just say so, instead of claiming they were able to get AA to work.
Bottom line is If the truck was built in the 'no AA' date range, it could have the latest available software (for the serial number) but not be capable of AA.
Hmmm... I don't have the truck in my possession at this time. I did see that but chocked it up to not applicable since my truck has apple car play just doesn't have AA. I guess I will check out that rpo code tomorrow. I found others that stated they had one and not the other and a flash/update fixed it. That's what I assumed I was dealing with.
Do you have it? 16? Software version number?
Does CarPlay work? I think you’re correct regarding trucks built w/o CarPlay . If it has CarPlay then I don’t believe you have one of the 2016 affected trucks.
Did they ever build a version that was CarPlay only? I thought if it had CarPlay it has android auto also.
Like I said, if they tested it, Make them show you how it works.
Not sure if this will help but it helped me. Delete your truck from andriod auto app under menu/settings/connected cars. Then plug your phone into truck vai USB settings and open the app and follow onscreen instructions your phone gives you. You may have to go back to the connection connected cars screen. Worked for me.
Sent from my Pixel XL using Tapatalk
This may sound silly but have you swapped your USB cord to see if maybe yours is faulty? I have a 16 sierra and note 8 and have no issues whatsoever with mine.
Sent from my SM-N950U using Tapatalk
They did the flash to support it on my truck three time until it worked.  The procedure is complicated and if the installer botches even one step it will not work.
That's not as silly as it sounds. I couldn't get mine to work until I switched it. The shorter the better (less resistance on the wire) and I wouldn't use any gauge wire higher (thinner) than 21AWG. The cheaper ones are 24AWG and don't transmit as well.
Android auto requires the transmission of a lot of simultaneous power and data.
Google the Anker Powerline+ series. They are inexpensive on amazon. They are braided, so they can take being pinched in the lid of the center console. Its the one I'm using, so I know it works.
I concur, Anker braided cables are the best. I'd also advise to stay clear of the flat style cables, they don't have much protection and kink horribly. e3ebcf898be92e20d4e8b421bed4b3f3.jpgfb605f57a893c995bd4b073316447d90.jpg
Yeah. Those are the same ones I have. They are all I use. I bought the red ones too so I could quickly differentiate them from all my other cables. They are high bandwidth and practically indestructible, and if you do manage to destroy them, they are cheap to replace. They also support fast (~1-2amp) charging, if your phone has that.
Going to pick up the truck soon. I got a call yesterday from a senior tech. It was indeed in need of the rare andrioid auto only update that was covered in a tab. The tech said he's only needed to do 2 since 2016, mine was number 3. Sounds like I got the right guy!!!
I usually buy the Amazon Basics lightning cables. I order a half dozen at a time. They’re just ok, I’ve had them fail on me, but in a house with 4 iPhones and 2 iPads, they somehow seem to disappear before they fail most times.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,273 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
