Wiring LED flush mount lights in rear bumber
I have a Hammerhead rear bumper with  Zilla flush mount led cube lights to install. I would like to wire the lights so they come on with my cargo/bed lights when the stock switch on console is pressed. The truck is 2014 Sierra SLE.  Will it be as simple as to tap into a wire going to the bed rail lights? The cube lights came with a harness and switch, so I could run them to the battery and the switch to the cab, but I would prefer to use the stock switch to keep everything clean.
Yes you can tie them into your bed lights if the lights don't draw too much power. Being LED you should be fine. What are the wattage rating of the lights? I would personally tie into the cargo lights and the reverse lights using a multi-function (SPDT) switch. That way you can have them on when in reverse, or on when you flip your bed-light switch. Let us know how you make out or if you need help with the actual wiring.
19 hours ago, wforrest08 said:
If I remember right there’s a couple different wiring options in this thread somewhere.
I post this response in the other thread yesterday, and I also posted a few months ago in the thread linked above.  Start reading right about here:
Yes it's easy to do if you have the factory LED bed lights.  If you have them the wire for them runs from the junction block above the spare tire, then splits and runs up each side of the truck behind the taillights.  Just splice into that wire on each side and you will be tied into the factory wiring.  When I press the factory cargo light switch below the HVAC controls I get cargo lights, bed lights, and bumper step lights all at the same time.
Thanks for the feedback. I went back and forth on it and decided to just do a dedicated switch in the cab. I could see times where I may want to have the work lights in the bumper on without the cargo lamp up top being on. There is a nice little flat spot just left of the steering wheel that is out of the way, but yet convenient to cut the switch on/off.  I'll get some pics up when it is all done.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
