I'm back
On ‎2018‎-‎09‎-‎29 at 3:53 PM, haider320 said:
Well, I'm back.  After trading off the 2014 GMC for a 2015 Jeep Grand Cherokee; the lease was up on the jeep.  We bought a 2018 Z71 Chevy silverado on Thursday.   We ended up getting 16,000 off the sticker price.  Glad to be back with GM.
Through experiences like yours, I've concluded long ago that a full sized 1/2 ton pickup is the best choice for a daily driver.  Every time the smaller vehicle or money saving bug has pulled me away, I've come back!  Last week, I was helping a relative shop for a SUV.  Some of them are very, very tempting!  However, climbing back into my pickup after  days of test driving the "latest and greatest" confirmed that they're not pulling me out of my pickup!(yet)
