Looks good! Get some rear fender liners. It will make the back end look lower in a strange way.
Rear fender liners, I didn't even know they were a thing. I'm really liking the way this truck rides and drives, it's a work truck and I drive it everyday. It's better than stock for sure.
Sent from my SM-G975U using Tapatalk
Yep. I like mine too
8 hours ago, Gtorres1995 said:
Anyone knowing the warranty still holds if you notch the frame for a 4/6 drop
Warranty on what?  I would expect GM to deny warranty work on significant portions of your truck because of that kind of modification...
Thanks for the advice, I didn't even know they were a thing. Makes a dramatic difference for sure. Thanks again. d8ac3b42241d947b812cd3d1b8187b24.jpg41c20fd2a22ebede4d0eab5f4830ee56.jpg
I notched mine. GM will void your warranty for any stupid little thing you do.
What brand lowering shackles are you using
Maxtrac Suspension (712120) 2" Rear Lift Shackle for RAM 1500 . I know it's crazy but that's the ones.
Thanks for the info I have the bell tech ones on now I’m just looking to go a little lower center hole to center hole on the bell tech shackles are 7-1/4 you have any idea what center hole to center hole on the maxtracs are?
Also have you had any squeaking issues with the maxtracs?
Edited by Godzl1a1102
What drop kit did you use,  this exactly what I need mine to look like .
What tire size are you running on this truck ?
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
