I have a bagged 2003 Chevy Silverado with a 5.3 engine and recently I decided it'll be a good idea to add a Level 3 cam, but before starting i was wondering what else should I take in consideration besides a dyno tune? What else is required for my truck to sound and drive "BETTER" ? It would be of great help Thnx!!!
Headers/exhaust will also make it sound and drive better, and stick with a smaller cam. The truck is too heavy to really take advantage of a large cam.
Your going to have to change your valve springs and a higher stall torque converter wouldn’t hurt either. The harmonic balancer puller is a must the rentals aren’t the right one in my experience
A Level 3 cam sounds like the typical grind that move the power band higher, losing 30-60 foot pounds of torque from idle and getting it back where most people don't drive daily, above 3500 rpms.
Keep lift at or below .502 and duration below 210 and you'll keep bottom end torque.
Totally agree with you hear the level one low lift from Texas speed is a good choice for this
I second texas Speed. Last time I did a cam they provided everything I needed. Lifters, cam, gasket sets. Only thing that did not come in the kit was the correct timing gears. Old one would not swap and they send me a different style. Worked great without a torque converter, but a higher stall would have helped a lot.
https://www.texas-speed.com/
Why would he keep lift down? He needs as much lift with as little duration as he can get--I would keep it around .550 to keep it reliable.
To keep the torque down low.  The only camshaft grinds that I've seen that have as much or more torque down low compared to stock for a big truck all limit lift to under .510; which is within the limit of the stock springs.
Check out this article and at the bottom pay particular attention to the Crane Cam Trio:
https://www.hotrod.com/articles/ls-cam-test-comparison/
high-lift won't cause torque to go down ever. Those cams are so different that they cannot be compared.
Remember the goal is to get air into the engine. If you open the valve farther, it is going to allow more air(unless you're beyond max flow of the head), valve timing is where you play with the power curve.
Open the valve for longer, the curve goes higher.
So your goal is to open the valve as far as you can for a shorter amount of time.
7 hours ago, vandenbroekjj said:
208/212 dur .550 lift great for everyday
I have been looking for a graph. Interesting curve.
    overspeed
    overspeed
  • Who's Online   2 Members, 0 Anonymous, 141 Guests (See full list)
