New AT4 option or accessory?
It's an option.  It says right in the article.
You can select it during your build online.
$5k for exhaust and intake ?
So does a full optioned out AT4 now sticker @ around 69k ? ( US prices)
The Standard AT4 package consists of a factory 2" lift, Wrangler Duratrac tires and 5.3L engine.
The $4,940 Off Road performance package upgrades you to the 6.2L with a Cold Air Intake, and gives you a performance exhaust as well as Goodyear Mud Terrain tires.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 498 Guests (See full list)
