Check Engine Light and 4WD Service light on 2018 Denali 1500 after install of Air Lift 5000 bags for my RV towing.
kbren
Long story short after installing my Air Lift 5000 bags I went to turn the car on to calibrate the Smart Air system for the air bags with manual air before hooking the on board air compressor relays up to ann Ignition source and I was getting limp mode via Check Engine and Service 4 wheel Drive Soon lights while the engine was low on power and shifting abnormally (had to drive it to the air compressor).
I can't imagine the airbags did anything to the tune (they just mount to the axles) and regarding the Smart Air II system, I merely hooked their relays up to the negative battery post and the positive battery blocked right above the pos battery post. Again, I never even finished the power by hooking up an Ignition source before these codes triped.
When it happened I disconnected the negative battery terminal and reconnected it and the lights were gone for half of a day and then everything came back on.
At this point, I took it to the dealer because I do not have a scan tool to check the codes in whatnot. The dealer is telling me that they had one of their "best electrician" on the it and he cannot figure out the problem they thought maybe I pinched an ABS brake line but they are now saying thats not the problem and they can't even reset the codea now because every time they do they come right back on. Service guy thinks there I might of done something to TCM by hooking up the fused positive wires for the relays to battery block on the positive side because he said that is a temperamental block post that directly goes to the TCM (head scratcher). I have a hard time believing that because it's just a large fuse aperture coming right off the positive battery terminal so I don't understand how that would have anything due to TCM.
Any help is appriciated!
Not yet. I'll get them on Monday and share... What a pain.
#1 mistake (too late now, but don't do it again) is taking a vehicle anywhere, even for warranty work, without knowing the codes first.  Knowing the codes gives you a leg up on anything they try to feed you.
This is what I use.  Reasonable price and the best priced unit out there that will give you more than just basic OBD codes (will do BCM and other modules - very useful stuff).  It paid for itself a couple times over with my last truck.  https://www.amazon.com/dp/B00652G4TS/ref=sxts_kp_bs_1?pf_rd_p=8778bc68-27e7-403f-8460-de48b6e788fb&pd_rd_wg=csHgV&pf_rd_r=ZRD3GYJRA9P76HJSZ99Z&pd_rd_i=B00652G4TS&pd_rd_w=zOHsk&pd_rd_r=0623044b-95c3-4256-863f-21c5005e3857&ie=UTF8&qid=1546799631&sr=1
#2:  If their best guy is throwing out ABS causing a limp mode issues, I'd be HIGHLY suspect of anything they told me.  You could have cut every ABS wire in the truck and it won't throw the motor into limp mode (it will light up the dash for sure).
Very well stated. I am getting the truck from them tomorrow no matter what they tell me.
I have that code reader on order. I'll get this figured out. After reading codes and doing self diagnosis I'll update but bottom line, if I take it to another dealer it will be the one further away from my house. The one it is at now is by far the worst I have had the pleasure of dealing with...
    • I think the answer is it's a stock 5.7 Hemi with a 3.0L blower bolted onto it 😉   Practically, because a blower introduces a lot of high pressure, severe thermal stress, and extreme mechanical loads on an engine. Things still need a little time to seat and get used to moving under load.   Sarcastically, because it's a Stellantis/ 5.7 Hemi and those things need all the help they can get!!
    • It's been a little over three weeks since my second knee replacement.  I can now walk around the house without a walker or cane but still have a lot of healing ahead.  This morning I was able to bring a cup of coffee to my wife in bed.  A few days ago, this coffee would have ended up on the kitchen floor!  Knee replacement surgery is very common and will typically enhance the recipient's future quality of life. However, the recovery process can present significant challenges, pain and discomfort. I encourage anyone facing a recommended total knee replacement to welcome the opportunity.  Just be aware that your body may take several months to fully welcome the new parts!
    • The Germans basically didn't make the list. There aren't a lot of shade-tree mechanics who work on them in general. At some point the economic equation of keeping a car alive favors junking it. Anecdote/experience tells me this is the case versus actual bad engines/engineering. Not that there isn't any, but there are definitely notable excellent examples. The 2.0 diesels will go forever and ever if one keeps the car around it running. The 2.0 gas cars eventually wear out their turbos but the block below it is usually still solid as a rock. BMW inline 6's same thing. Mercedes diesels of yesteryear, not uncommon to see 250k out of those engines, easy.     Link to the synopsis of the study: https://www.iseecars.com/longest-lasting-cars-study
    • 0w20 is recommended in the Sequoia. 0w16 in the Highlander Hybrid.   I think you make a compelling case for both the quality and frequency of maintenance but I wouldn't go so far as to plot a linear relationship between longevity and oil weight 😉   The list is interesting and leaves me with some questions. The Silverado 1500 is 12.9% likely while the GMC Sierra 1500 is only 10.8% likely. Arguably, they're the same truck, so other factors must be influencing the outcome.   The Honda Odyssey ranks #12 at 13% likely. Great. Rest assured we'll never stop hearing about the dang thing LOL.   There's a bit of a spread between the 4Runner (32.9%) and Tacoma (25.3%). Both overlap on the same 4.0 for many years although the Tacoma used a 3.5 for the last 10-12ish. I wonder if that's related to use-case or if it's suggesting the 3.5 isn't quite as up to the task, or maybe something else fails mechanically.   Ram at 3.5% overall likely, but the Ram 3500 holds the top spot on the Heavy Duty Models at 39.7%. One might say the Cummins is a ringer and provides an unfair advantage. I don't think it's fair/accurate to pit the GM Fullsize 1500's in a list with HD's which are basically medium-duty wearing a 3500 badge.   The Tahoe and Suburban hold spots #15 and #8, respectively, on the longest lasting SUV's list. What's the difference? One's got a shorter butt, unless they're also counting the 2500/3500 Suburbans in those numbers.   The GMC Canyon gets a 1.4% increase over its twin brother Colorado. Why, because it's prettier?   SO many questions...
    • Have the aftermarket system removed an re-test.  Its pretty much the only way to know if there is still an issue that is the truck and not from that.
