Longtubes/catless y pipe sewing machine
scottie350
Ive been looking at that kit, how loud was it w the SE mufflers? Mostly at cold start? 530am starts wondering how POd neighbors gonna be lol.
As for the valvetrain i likely hear it so much bc im focusing so much on it when driving, but yeah def at drive throughs  ill deal w that later haha
It was loud. Yes, mostly at cold start. The truck sounded a little lopey like it had a stage 1 cam installed. I pretty much had to idle out of the subdivision to try to show some consideration. The tone was so deep that it wasn’t too bad even though it was loud.
It’s a great sounding exhaust. Absolutely without a doubt worth every penny of the $400 they charge for it. I did the axle dump which explains a lot of the drone that I got inside the cab. Just keeping up with normal traffic while accelerating from a red light sounded awesome though.
One thing to keep in mind, we all speed up for whatever reason while driving around and no one really bats an eye. When you get on it with this exhaust, no matter how reasonable it is to accelerate quickly, it’s gonna sound like you’re drag racing and everyone within a quarter mile will know it. That said, it’s a sick sounding deep scream that can’t be captured by the microphones of my camera or phone.
If you live in an area with a lot of gear heads or if your neighbors are into cars, it will definitely put a smile on their faces.
If you do get it, buy a handful of the large stainless steel band clamps. The ones in their kit have been improved from previous versions and work but the system looks so much cleaner with the big clamps.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
