6.0L will not heat up
I have a 2000 2500 with a 6.0L. Just purchased the truck. And it had a leaking radiator. So I replaced it and i can't get it to go above 160f on my scanner. So than i replaced thermostat thinking it was stuck open, and same deal. Shouldn't it be closer to the hallway mark about 210?.
Next I would:
1) run the engine up to temp (driving around for 15-20 minutes should do it)
2) use a IR gun on the engine block/hoses/etc and see how hot they are.  Should be about 90C, 195F, or possibly higher, depending on ambient temp and driving conditions
But I would think the next thing to look at would be the temperature sensor.
 Is your belt on correctly
 Make sure the fan is disengaged right after start up, as it warms up, the cooling fan should be non operational. If its always running, that could cause this.
 Also, if you run a stock T stat, make sure your trans temps stay below 195 so you do not cook the transmission. A aftermarket cooler will easily install where the small stock one lives now just behind the grill.
  I have run a 160 T stat in the summer when I tow more and have had no issues, or codes. In the winter here, the stock `195 is a must though.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
