39 minutes ago, willy_usn said:
What hole covers are those??  Bought a 2018 with the factory kit and cant find covers anywhere!
I ordered mine from the local GM dealership, I wasn't sure what the part number was but they were able to pull it up and order them for me.
On 4/1/2019 at 6:43 AM, Gmman said:
What size hole saw did you use and did you cut them from the bottom or the top?
Great info and pictures!
What diameter holes did you cut to install?
What are the part numbers for the covers?
I just bought a factory hitch off a 2016 Sierra to install on my 2018 Silverado 2500Hd... ready to start.
ToddMc
I found an extra cap that I had for the smaller holes but I can't find any info on the larger center cap. I traded that truck in on a 2020 so I can't look at the center plug. Attached are pictures of the smaller plug. I'm sure the local dealership could help you out with them.
On 2/13/2020 at 6:49 PM, ToddMc said:
I used a 3-7/8" for the large center hole and a 3-1/2" on the smaller holes. I drilled them from the top, on my 2018 the factory put small dimples in the bed for the hole locations which made it pretty simple.
I am starting this project now. The part arrived today. However it did not come with any bolts to mount it to the frame. I will be heading back to the dealer tomorrow to get the bolts. I have a 2018 Chevy 3500hd, dually, long bed, 4wd. The part number I got from my dealer is 84164444. As stated before, this does NOT include the new heat shield (which I also for got to get) the mounting bolts or the caps to cover the holes in the bed. I ended up getting mine from gmpartsnow.com. This is a Chevy dealer in Grand Rapids, MI. I found that the biggest difference in price is the shipping charge so shop around.
So, I need to remove the factory system in order to install the Turnover Ball / Companion system from B&W.  It looks to me like I can disassemble the Chevy rails under the bed (so I don’t have to lift the bed up 7” as you did to install) but I can’t say for sure.  What do you think?
  • 4 years later...
On 4/2/2019 at 8:12 AM, MrChips said:
I will look when I get home tonight to see what size of hole saws I used, I cut them from the top. If you look closely at the bed floor you will see 5 small indented dimples, they are in the exact location where the holes need to be cut. The pilot drill bit on the hole will center up on the dimple nicely. I will let you know what size of hole saws I used later.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
