Auction Buy - How to know if remote start is installed?
Hi All,
Just bought a 2018 Sierra SLE from Manheim auction and recieved the non branded 3 button FOB with just lock, unlock and panic buttons.
Pressing and then press and hold does lower all the windows.
How can I tell if remote start is installed without a remote start FOB?
Email your vin to [email protected] and ask for a copy of your build sheet and a copy of the service records.
I’d guess you’ll get a response by the end of business tomorrow don’t know if anybody there works Sunday Fun Day...
If you have remote start you will have this code on your build sheet.
BTV - REMOTE VEHICLE START
That RPO code should be in your locking glove compartment
I don't think they do this in 2018.  I understand that there is  barcode that needs to be scanned inside the driver's door. (?)  wforrrest08's suggestion will result in good information to keep with the vehicle.
There is a QR code on the driver's door post. Download a free QR code reader for your phone. It will have all of the RPO codes.
I tried 2 code readers and both just showed the vin# with searching the web for it.
Sent from my SM-G950U using Tapatalk
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 630 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
