My 2019 RST 5.3L has them, I noticed by accident as I normally seen the radiator when I was cleaning it but seen the shut louvers instead! Definitely temp sensitive as they were open all summer. Saves the hassle of putting in the ol cardboard before the temp drops to -40C, lol.
Edited by Morphy72
  • 4 months later...
Anyone have any idea as to how to delete them in a truck or making the truck think they're fine? They're giving me error code p05ae and preventing me from remote starting my truck. I have zero intentions on replacing them as they are just falling out.
OP here just to update, traded in my 19 and got a 23 HC a few weeks ago with the shudders i originally wanted, truck provides heat when i leave work at 1am in 1/3 the time it used to here in upstate NY.
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
