On ‎3‎/‎5‎/‎2019 at 12:46 PM, z1boss said:
Here are the complete step by step instructions to get to the Passive door locks settings.
1.  From the main menu, click Settings.
2.  Click Vehicle in the top right corner.
3.  Click the down arrow to scroll down once and then click Remote Lock, Unlock, and Start.
4.  Click the down arrow to scroll down once and then you will see the two Passive door options.  From here, you will be able to change the settings.
Let me know if you try this and you dont have these options.  Just curious if my theory about Convenience Package 2 is correct.
Yep finally got it squared away, thanks for the help
  • 1 year later...
On 3/3/2019 at 8:04 PM, towdog333 said:
Just found out that the door handle button locks the door but won't open ?????
Have a 2019 Tahoe only 12K miles that continues to have handle button issues. Have return to the service department 4 times only to hear "It's your problem" Chevrolet has "no Issues with any door buttons". Tahoe is back at the dealership again today, drivers button doesn't work. Now the service manager claims it's the antenna in the door not working? Claims Chevrolet knows about "some issues" but has no repair or knowledge of any issues. Ask that I come get the truck and keep using the FOB to lock and unlock the door. Anyone got the same issues or know the repair for this service group?
I have a 2019 gmc elevation that the doors will not unlock when the handle button is selected.   It worked yesterday.   Remote works fine locking and unlocking the doors
When select button all doors should unlock (passive door unlock setting)
If my key is in the same pocket as my phone the door handle buttons will not work. Switch the key to an empty pocket and works no problem. Just an FYI for you guys.
Sent from my ONEPLUS A6013 using Tapatalk
Thanks, although it’s not the problem.   This may be the result of me opening my truck windows with my remote and hitting several buttons before getting it right.  I’m not sure so I didn’t want to add it initially to add more confusion.
On 3/4/2019 at 2:43 PM, z1boss said:
Yeah that's a temporary disable with a re-enable.  If you go into   Settings>Vehicle>Remote Lock, Unlock, and Start you can set what the buttons do under Passive Door Lock and Passive Door Unlock.  Mine is set to unlock only drivers door if pressed once on the drivers door button and unlock all doors if pressed twice.  Pressing any door handle button while unlocked with lock all doors.  I also have automatic locking enabled for 5 secs after closing all doors
I have mine set to open all door with push of the button on the handle as long as I have fob in my pocket.
Thanks to the person that stated to press the lock/unlock button on the remote at the same time to make the outside door lock buttons work again.  That did the trick!!!
P.S. Don’t buy a new generation GMC Sierra 2019+ unless U like recall after recall, leaking window, flooded floor and no available parts (carpet) and a transmission that shifts like a 1972 dodge power wagon.     If no service fault indicator It can’t be fixed.
Sorry, GM owner but what piece of ’*^*%!   Chevy is having similar issues but not as bad as GMC.  JDP Initially quality my ass.  Maybe the last 2-3 years of a generation after years of figuring it out.
Anyway, thanks for your help. I’m sure I’ll be using this site a lot or banded from it.
Can you say 5 weeks, that is how long my brand new truck has been at the dealer   Do you know what GM offered me for the BS I had to deal with, free Onstar for a couple months.   Really!!!!
  • 1 year later...
On 3/4/2019 at 11:46 AM, towdog333 said:
I didn't see anything in the setting menu for door handle locks, but will double check again. Plus they worked before and I know I didn't change nothing on any setting
Settings - Vehicle- - Remote Lock, Unlock,Start - Passive Door Unlock
I'm having a similar issue with my 2020 Sierra HD Denali. The doors will lock/unlock on both passenger door buttons, but not on either driver side doors!! any thoughts? TIA
Yes i have the same vehicle and mine just started doing the same thing  2019 GMC elevation !!
Nothing yet. I’m still within the warranty and soon will need an oil change. I’ll have them look at it then and post the “cure”
  • 1 month later...
so have my truck in for this button problem. GMC is telling me that there is an antenna inside the door that
senses the fob, and that is what's wrong. They also said my drivers door window had been replaced since there was some shattered glass inside the door and whom ever replaced it did not replace an internal seal causing water to enter the door.
They think that's what caused the malfunction with the buttons on the driver's side. so they also have to order that seal but it's not covered under the warranty. Guess this is what happens when you buy a used vehicle (especially with low miles). Can't imagine that rain/water would have broken that antenna/feature in 13,400 miles!! When i pick the truck up i will question them more.
Edited by obazsm
On 9/8/2021 at 10:13 PM, Timothy Richardson said:
Thank you good luck
Locks are working properly, read above for the fix (at least what fixed mine)
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 523 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
