Someone stole my wheel and flat tire out of my 02 2500 hd and I hoped one of you might know where I can get one? It's a 17" 8 lug gear alloy "recoil" and has been discontinued. Help!
I would just buy “new” wheels. The chances of finding those wheels are slim and even slimmer to not end up buying a set. You can pick up a set of nice stockers or H2 wheels for $400-$600.
