Simple Secondary Cargo Light Switch
Well, relatively simple at least.
I was tired of having to go into the truck to turn the cargo lights on and off, so I wanted to add a secondary switch in the bed. I searched and found multiple results about adding a secondary set of lights, which was not what I was looking for, so here's my solution.
I wanted to add a secondary switch to turn on/off the factory cargo lights, and retain the 10 minute auto-shut off. Through some searching I found that the switch in the truck works by pulsing a momentary ground to a pin on the BCM, which is pretty easy to replicate/extend.
Materials:
Wire. I used some red/black 2-wire, I'll explain why later.
A small scrap of solid core wire.
2 waterproof push button momentary switches.
Here's what I did:
Soldered a small scrap of solid core wire to both leads to the red/black 2-wire. This made it easier to tap into the BCM.
Tapped into pin 18 of the blue plug on the BCM. There's a solid gray wire on that pin.
Ran the wire out of the cabin (using this method:)
and then down the underside, following a large bundle of wires and using some wire clips that GM/Chevy was nice enough to leave available for use.
Popped out one of the cargo tie down plugs, and ran the wires through. Here's why I used the red/black 2-wire - measure enough wire out to go back through the hole and then under the bed to the other side, then cut. Now we have enough wire to install a switch on both sides of the bed.
Drilled the plug to fit the push button momentary switch, and installed the switch in the plug.
IMG_7153.thumb.jpeg.9a1d8de914719fc4c0bc5e63da68e71a.jpegIMG_7154.thumb.jpeg.15b79e137f88f4d0618de12cadf31a41.jpeg
Cut ONLY ONE of the wires at the drivers side hole, and wire it to one lead of the switch.
IMG_7152.thumb.jpeg.119f6c3a461b80c18323fc488362224b.jpegIMG_7155.thumb.jpeg.238e416d0722bbb287c3c833eb0372ee.jpeg
Connect the scrap of wire you just cut off (red in this case) to the other lead of the switch. Run both the red scrap and the black wire back through the hole, and reinstall the plug.
I didn't take any pictures of this part unfortunately, but run the red scrap of wire to any grounding point and secure.
Then run the black wire to a cargo tie down plug on the other side and repeat the steps to wire and ground it.
Then enjoy your 2 new readily accessible cargo light switches!
IMG_7160.thumb.jpeg.4a0103f08bbcb7aac0e2d61ecc30ca05.jpegIMG_7161.thumb.jpeg.49791e94f305486b4827aecfe87c5823.jpeg
This activates the same as the cargo light switch in the truck, so any modifications you've made like the reverse lights on with the cargo lights will work just the same as if you pressed  the switch in the truck, and retain the 10 minute auto shut off.
Any comments/questions/clarifications please let me know and I'll do my best to get back to you!
way to go, that is how it should have been from the factory.
GOOD IDEAL - my truck came with bed light's , plus I add a 36" led strip across the front for more light . Just need to installed a rear switch.
Okay pardon me for having a brain fart but what if I only want 1 switch on the driver side?  I guess I just don't understand tying the black and red together with 1 lead where it goes into the BCM.
Also any info on the switch you used?
10 hours ago, xMEATxHAMMERx said:
Def a cool mod! But I still like the cargo/reverse diode mod better. It's way easier, plus you can use your key fob as a switch.
Key fob works great for me, but the lights don’t stay on for 10 mins like it would with his method.
Yeah, I just keep hitting the key fob as needed to keep it on. You can increase the duration the lights stay on, in the radio.
And as always... Enjoy your ride!
Sent from my SM-G955U using Tapatalk
If you just wanted to do one switch, you could just use a single wire run from the BCM back to the switch instead.
Switch: https://www.amazon.com/dp/B075N18PXT/ref=cm_sw_r_tw_dp_U_x_NuJICb908RQZ5
  • 1 year later...
I’d love to do this mod to my 2015 Sierra. Can anyone tell me which pin out I need to use to feed the momentary switch at the bed?
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,304 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
