Cold Air Intake 5.3 question
On 3/26/2020 at 1:56 PM, Aaron1085 said:
So about a year and a half ago I installed a brand new CAI made by K&N on my 2015 Sierra 5.3 with approximately 23,000 miles on it.
Since then, I have to say, I haven’t been wow’d.
-Here in New England, it seems the colder air (below 30) seems to generate lower MPG’s.
-The constant intake sound (while cool sometimes) is louder than anticipated and I find myself using more effort to adjust throttle position to quiet it down.
-Throttle response and ‘power’ improvement is questionable.
**This K&N Intake has been extensively reviewed on here with generally positive results from members. Also the biggest reason I picked it up. I do like the smooth intake tube which I think is far superior to the stock set up. But I wonder if I could run the same tube and put the stock airbox back in with a better filter. Any insight on that before I start taking things apart?
Or the flipside, I could just sell the whole set up. I have the box and I just clean the filter. Anyone interested? (Located in Southern New Hampshire).
#QuarantineLife ?
I’ve had the same experience to the point I am thinking about going back to stock.
If you ask me the noise sounds like ******. I am also getting about 1 mpg less. Thought this was to increase mpg ?
I temporarily took my AFE Momentum GT off and put the stock box back on. I was getting a headliner buzz / rattle which If I push on or near the overhead console it would go away temporarily.
I Dremeled out another hole in the stock box to match the metal fender cutout. Not sure how much that will help airflow on stock box but it was a free mod.
I may end up selling the AFE but will run stock box for a bit and see if rattle is still there.
Took my K&N CAI off this morning - one test drive back to stock and already noticed it silenced my exhaust.
I have a flowmaster 40 with third cat and resonator removed. There is a def sound loss with the stock Ai.
Quick update after a couple of drives
I would say the exhaust tone is not lost - just less cabin noise with stock air box
On 3/13/2019 at 7:00 AM, 1SLOW1500 said:
But I also reset my re calibration parameters to lower setting so it learns more often.
You would have to search for it. But it is like disconnect the  battery start truck let idle then wot a few times so the idle tables are set but that is after truck is at 180* so the idle tables are right. Even the GM intake says retune by dealer. But its a relearn not a "tune".
good to know..
    blueskytruc
    blueskytruc
  • Who's Online   3 Members, 0 Anonymous, 583 Guests (See full list)
