lowering kit problems
Hey guys i am new to the forum let me induce my self my name is jeremy and i drive 2018 sierra double cab 4x4 sle which i am looking into lowering
MY problem is i ordered the 34170 mcgaughy's kit and when i bought it they didnt specif that i need to have the older style cast arms in which i have the stamped arms
so would i be able to swap just the lower arm to the older style cast? or do i have to switch both arms?
I'm struggling to overlook why you'd lower a 2018 4x4, but I think that the only difference on the control arms pertains to the uppers. 2017 and up uses stamped upper control arms. 2014-2016 is cast. Lowers should be the same. Either way, you can buy a set of upper control arms for a 2014-2016 and that will bolt right on.
Sent from my SAMSUNG-SM-J727A using Tapatalk
No, return it and get the correct kit for stamped steel arms,  the stamped steel lower control arms on the 18 use a larger, heavy duty ball joint, same as the aluminum arms.
Is there an ability to specify which? I'm under the impression there is not, which is why I said to change the upper control arms out.
yes, they make a kit for each control arm style.  aluminum and stamped steel are the same kit.  and it's the lower control arms that have the different ball joint sizes.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
