I have a 90 Chevy k1500 4x4. It has the 5.7 350 tin motor. The motor has been completely rebuilt all sensors, ecm. Original prom chips in the ecm. The motor runs like crap. Up and down idle. Almost die’s when In gear. Found oil on all spark plugs some much worse than others. Tore the motor completely apart. Some pistons are black with a sticky almost like paste on them. Some pistons are clean like never been ran. I will attach pictures of pistons.Some head bolts smell like 80w gear oil. Oil in pan looks grey and like the oil is separating from something else. Can’t tell what foreign liquid is. I need help under stand what is the cause of this on the piston 70ea588d4bb408b82e2fda8e19fbeed5.jpg08bb3bae97f097c010afe8b67c87f79b.jpg
Probably a "blown" head gasket.  Head might not have been torqued down right, bad bolt(s) or poorly prepped surfaces.  If the motor had just been rebuilt and the first oil change not even done yet, various assembly lubes would be found in the oil and have now probably mixed with the coolant.
should have done a compression test , but to late for that to me it looks like the intake gaskets where leaking and that is why you have clean cylinders  those ones werent sucking in fuel the other really black cylinders could be from poor ignition not enough spark or incorrect timing
I am with this, looks like excessive fuel not burning on that one cylinder. See if you can get the head checked and make sure all your rings are good on the cylinder. Excessive blow by on the cyclinder would cause low compression and bad detonation. I have also seen this cause grey oil in the pan. Worth a look see as you have it appart.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,164 Guests (See full list)
