2017 Denali unsolved problem
Sometimes I can get in my 2017 Denali pickup with 28,000 miles and put the ignition switch in the start position and nothing happens. The dash lights go out but the headlights don’t even dim. The headlights are on because the truck is inside the garage. This usually only happens after the truck has sat for a day and night or longer. The battery voltage remains above 12 volts. The local parts house checked the battery and it shows to be good.  After I get it started by connecting a battery charger at 50 amps it does fine the rest of the day. I have cleaned the battery cables twice, moved the battery cables around while the ignition is in the start position with no luck. Since this seldom happens, the dealer can’t find the problem. It happened again this morning and I tried the remote start and the engine started right up. Later, I noticed the volt meter was reading lower than usual but returned to 14 volts after restarting the engine. Any one want to make an educated guess of what might fix it?  Thanks
When it doesnt start the is a soft code report. Dealer knows this but never seam to tell customers. There are some tsb that state batter cable issues. Also remember there is a ground strap to the firewall. When you said test good does that mean it was load tested or just voltage tested? Big difference. I would also have the alternator tested but again if the truck isn't telling the alternator to up output then there is your issue. Once mine did that as the truck sat for 2 weeks. When it started I looked at the gauage at it read 15.2v so the alternator is trying to charge up that battery. All day every time I stopped the engine it wouldn't restart. Buy the afternoon battery was back and I was good to go. But as I rarely drive the truck I have 2 batteries and a isolator. So I can push a button and start the truck any time I like.
The fact the truck wouldn't start this morning via key but did via remote start tells us several important things - it isn't the battery, grounding, alternator or battery connections.  Otherwise, it would have had the same issue via remote start.
I'm leaning toward the key cylinder or something related to the keyed ignition.
I think you may be right. It did it again this morning and started with remote start. It’s getting to do it more often and maybe the dealer can see it happen then locate the problem. Like you said, probably the ignition switch.   Thanks
  • 1 month later...
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
